Surface Pro 3 does not connect to recent Samsung Series 7 TV
2014-09-21T16:09:32+00:00
my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
I would appreciate to get this working again.
Thx,
Bernd
    2015-04-12T15:28:52+00:00
    Sony UHD tv's don't work with Surface Pro 1 either via Miracast without an adapter.
    I can send the Start screen from my SP1 and then it stops and the TV is sittting there waiting for more signal which never comes.
    If it was impossible to send to the TV without an adapter, the Start Screen would never appear on the TV at all.
    If Sony's Whitelist was the problem the Start Screen would be unlikely to appear on the TV either.
    The TV sees the Surface Pro and the Surface Pro sees the tv and it even shows up in device manager.
    But the SP will only send the Start Screen to the TV and nothing else.
    People have been complaining about this since the first generation of UHD tv's came out in 2013.
    Would you please ask the powers that be at Microsoft and Sony to have a programmer or two take a look and FIX THIS?
    I can let them know but I can't guarantee they will look at the issue. Question for you - what happens if you start (example) playing a movie and then start the Miracast session? Or start from inside an app ?
    2015-04-12T14:55:32+00:00
    2015-04-07T20:51:06+00:00
    Ah. They know about issues with Samsung devices and Miracast on the SP3. I am personally working with someone myself on this. I don't think the fix will be a quick one. And yes, these Samsung devices work fine with everything else on the planet that uses Miracast to project. I feel your pain.
    2015-04-07T19:50:30+00:00
    Hi Barb,
    I use neither a cable or an wireless adapter. I think, it is via Micracast (according to samsung says screnn mirroring).
    My SP1 finds my tv both a playback device and a wireless display. Both work fine. My SP3 finds tv as a playback device only, the streaming of video via media player is more than very poor. streaming of pictures is ok.
    Tim
    2015-04-07T09:41:47+00:00
    On Mon, 6 Apr 2015 19:38:30 +0000, tim mauer wrote:
    >>i have seen and read the post "Surface Pro 3 does not connect to recent Samsung Series 7 TV". Mein Problem is nearly identical: my sp1 connect smoothly my TV (UE55H6270), but my SP3 just does not connect it!! I tried to reduce the screen resolution of SP3, 1920x1080, 1080x768 and any possible. Unfortunately None of these worked!  Further Search via google was brought no more infos or solution.
    >>Does anyone have any ideas?
    is this using a wired cable? if yes, what cable are you using? or is this via
    Miracast?
    Barb
