MICROSOFT THIS IS NOT GOOD ENOUGH. HUNDREDS OF SURFACE OWNERS (including me) HAVE THIS PROBLEM BUT YET YOU DO NOTHING ABOUT IT!
WHEN ARE YOU GOING TO FIX THIS?
I have read many posts and made many attempts to correct this problem without any success.
I was traveling for 3 months and when I returned the battery was completely dead.
Also, each night since my return, the battery drains as much as 12% overnight while shutdown.
I have all MS updates but the problem continues.
Please advise.
THX! :)
I have a surface pro 4 and noticed that when shut down completely, the battery is still draining. At first I just thought I forgot to shut down and put it into sleep, but after a few times of this, where I would not use it for a week or two and finding it dead, I realized there was an issue. After some research, I realized there was a setting called "Fast Startup". I turned this off and noticed an improvement (although I think there was still a bit of a drain). Now after the most recent Windows update, I noticed the problem more. Turns out the setting was back on, and I turned it off. Yet, after doing so, I am seeing a battery drain of 10% within 24 hours of being shut down. I don't use this every day, so is going to be an issue of opening up a dead surface that needs to be charged because I haven't used it in a week. Is anyone noticing this problem, and have any recommendations? Thanks.
So, I charged SP4 to 100% and shut it down. But when I on it after 24hrs its at 83%.
Will you consider this as normal?
Within 24hrs I find that it drains by atleast 10%. Can I see the changes from battery report?
What is your definition of "massive"? With Connected Standby, on battery, I've seen 1-2% per hour at times depending.. Your sleep study shows all in the green with no "offenders".
