Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-09-10T14:57:42+00:00
    I had extracted (used DriverMax) surface Pro Touch Controller Firmware and put in one drive (it works on mine, but try it with your own risk)
    here is the link
    http://1drv.ms/1qEScSA
    2014-09-10T13:49:23+00:00
    some reason driver is there but it just not installing. I had to replaced Surface Pro3. If you go to MS store, they will take a look and if they can't resolved it, it will be replaced. that's how they did it mine.
    2014-09-10T08:11:28+00:00
    Same Problem here,
    No luck with Aug.19th and Sep.9th firmware update!!!
    As the touch controller firmware is still version 426.27.66.0 (5.15.2014 released);
    When can we get the touch controller firmware update?
    2014-07-09T04:23:09+00:00
    The method you are defining is for home user not for corporate. We have thousands pc, tablets, can't stick usb key to refresh, we use pxe to reimage computer.
