Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-11-23T13:31:56+00:00
    Having the exact same issue.  2 support chats later and a reboot AND a reimage.....still same issue! Just got my Surface Pro 3 11/3/14 - hope this purchase was not a mistake!! It seems to be working fine so not even sure (I'm not tech savvy) what this particular firmware does in regards to performance.
    2014-09-12T02:41:25+00:00
    this is the latest driver for touch controller. I think  you need to replace this unit.
    2014-09-11T23:53:00+00:00
    Orionbelt, no luck with your driver, but thanks!
    Still waiting for touch controller firmware update!!
    2014-09-11T09:46:44+00:00
    I had extracted (used DriverMax) surface Pro Touch Controller Firmware and put in one drive (it works on mine, but try it with your own risk)
    here is the link
    http://1drv.ms/1qEScSA
    Thanks for your files, Orionbelt;
    I will try it, get back later;
