Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-07-09T03:58:47+00:00
    Non-standard methods? I am not sure what are you talking about. I am using MDT2013. If you think thats non standard method, than i am not really sure what are you talking about.
    Anyhow, i had replaced pro 3. I am going to wait for windows 8.1 update 2 coming end of this month or next month
    What I was simply going for was... the options available on the device... Refresh, Replace, or even the Restore with the USB Recovery disk.  The 'recommended' methods for the device.... If you put together, or have access too, the deployment kit with the OEM packages and payloads... that's fine.  Not many people here do... that's all... nothing more intended than that....
    PS
    2014-07-09T03:14:49+00:00
    2014-07-07T03:36:02+00:00
    I am afraid to reimage my another Surface Pro 3, since it has been happening to so many people. I am not sure what MS plan is.
    Listen, this is a brand new device..2 weeks old.  you've done recovery. It has not worked.  you should not have to do any further tinkering... using other images, or methods to reimage, is silly... right now.  have them replace the thing... the more you mess with non-standard methods, the better the chance you do something that violates some warranty or some thing.
    Get it replaced.
    2014-07-07T03:02:38+00:00
