Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2015-01-08T22:14:15+00:00
    At least that is a step forward! Thank you for sharing this information. I'm on my 3rd Surface Pro3 and have the same problem. So I guess the best option at this point is to wait for the fix? I just don't want the warranty to run out prior to the fix
    2015-01-08T20:36:10+00:00
    I had this same problem with 7 brand new Surface Pro 3 devices I purchased in late October.  Been fighting it ever since.  Looks like Microsoft has finally acknowledged the issue, but they don't have a fix yet.
    http://support.microsoft.com/kb/3024327
    -James
    2014-12-31T01:30:59+00:00
    Davidwoosh, hello. Yes you were right, our unit did not have the same number so after update it worked fine thank goodness. It appears to be a batch of faulty ones , such a shame as we really like the surface. A family member also has one and we have told her what to look out for. Cheers.
    2014-12-30T10:11:49+00:00
    check the revision number first before you update if it ends in 41 or 42 you should be ok.
    When i replaced mine I was worried too but after checking the revision I just went ahead and done it.
    I noticed when it updated the firmware the surface logo stayed on for longer unlike the last one i had it just flashed up and reset instantly .
    Everything is working excellent now :) excellent piece of kit :)
