Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-30T05:42:22+00:00
    Orion, we are having the same problem Our pro 3 is only two weeks old and we have spent two hours on phone with tech support ( not fixed ) then another two hours with MS only to be told to return to store which we have now done. going to give this one a go. Does not show problem on touch controller, but affraid to update incase the problem is in the update. fingers crossed.
    2014-12-27T01:52:55+00:00
    "Now to address my pen not showing up in the bluetooth setup:
    After doing some online research it would appear that a possible explanation would be that the button batteries discharged somehow during transit.
    I will post when I have tested this theory."
    OK, follow up is complete.  The button batteries in pen cap were the problem.
    Computer recognized and paired with pen.
    2014-12-23T17:39:56+00:00
    I got my replacement and everything updates first time no problems.
    It seems to be a specific revision version that has issues updating the firmware.
    2014-12-22T16:32:42+00:00
    you were correct and i needed it to change onenote to onenote desktop via the surface app.
    I took it back to the shop i got it from and got a full refund. Would have got another but had non in stock :(
    gonna try and grab one from another place tmoz
