2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-11-24T19:13:20+00:00
    I'd personally be thrilled with 5 hours using Windows Anniversary Edition 1607.
    I can't comment on the condition of your battery. Especially without seeing a
    full battery report. And even then, it may not tell a complete story.
    >>Instead of 10 hours of battery, I am getting about 5 hours.
    Being a Tech Coordinator I am all about performance, but also want the best life out of devices.
    This Surface Pro is my personal device, but we do use them at the District and I am always trying
    to make them work "better". Of course, at times I have to accept that it is as good as it gets and live with it.
    Sometimes convincing my wonderful teachers that is easier said, then done.
    I'll run a battery report again in a week and repost.
    H(N)appy Thanksgiving to you!
    2016-11-24T17:25:18+00:00
    2016-11-24T15:44:40+00:00
    If you've been through everything at
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10
    then you need to contact support
    https://www.microsoft.com/surface/en-us/support/contact-us
    Barb
    Windows Experience MVP
    Barb,
    I do not come except, when I have issues.
    My question is battery related.
    Lately I have seen my battery performance reduced "some".
    I just adjust screen off and sleep time while on battery to a lower level. They were at 5 minutes before turning screen off and 15 minutes before putting surface to sleep. Now at 3 minutes for screen off and 10 minutes for sleep.
    Do I need to be concerned or am I experiencing normal battery drain?
    I did run a battery report yesterday, but it only went back a month and doesn't appear show too much degradation. Honestly, I am not sure at this point what to look for, but would like to know.
    I am tech savvy and have a good background in tech, so I want to know the steps if needed to be taken.
    Thank you
    2016-11-22T08:04:28+00:00
    It cost $600 replacement here.
    My battery some how shows no detect on windows and don't charge after August update.But my surface work after AC unplug in the beginning.And my battery died slowly from not charged.
