2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-11-21T21:23:23+00:00
    Hey guys, for the past couple of weeks (since the firmware update) I've noticed that the charge on my SP3 seemed to drain fast and sometimes when it got to around 50% it would cut out and when I tried turning it back on it said the battery needed to be charged. I think I have found a way round this problem that works for me but can't confirm whether or not this will work for everybody and still need to test the battery draining a bit more but so far the decline seems to be steadier so here's hoping this way works. Since I was convinced that the issue for my device was software related I tried everything MS suggested such as uninstalling and reinstalling the battery driver, checking for updates and even wiping my machine and none of these seemed to make a difference. Since the MS support told me to make sure that the firmware was up to date I decided to see what would happen if I rolled back the Surface Pro Embedded Controller Firmware to see what difference that would make, it is currently on driver version 38.9.50.0.
    For those who don't know how to do this, go into device manager then expand the firmware block then double click on Surface Pro Embedded Controller Firmware and click on the driver tab and then click roll back driver.
    Like I said above there is a chance that me doing this and my surface behaving better could be coincidence but (for me) it seems that this was the problem. I hope this helps.
    EDIT: Oh yeah, just in case it helps, I have the 128Gb i5 SP3s with a simplo battery
    2016-11-18T22:35:30+00:00
    This is pretty sad. I paid over $2500 for my system and my battery died right after the one year warranty expired, support is telling me I have to dish out $450 to have a replacement or exchange, this is outrageous. I can't even update my computer because my battery does not even charge. I am very disappointed at Microsoft for their poor customer service regarding this issue.
    2016-11-15T21:22:15+00:00
    all you can do is contact support and discuss with them.
    https://support.microsoft.com/en-us/help/13948/global-customer-service-phone-numbers
    2016-11-15T20:48:31+00:00
    Oh, I am so jealous! My Surface Pro 3, purchased in July 2015, had the battery capacity start diminishing right after the 1 yr warranty expired. Within about a month, it got to the point that it doesn't think there is a battery (taskbar says 70% charge, plugged in, not charging), but if the power is unplugged it shuts down completely no warning. I had first tried installing the firmware update that supposedly fixed it, but it wouldn't update firmware. Upgraded to Windows 10 PRO, updated firmware, says it completed successfully, no change in battery problem. Complete wipe and reinstall to factory settings, still won't work on battery. Some pages I've come across say that the Power Cover will give you 2.5 hours of battery, but I have it, and it doesn't even give 1 second. GRRRR. Definitely re-thinking using Surfaces since the battery isn't replaceable.
