2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-13T18:54:01+00:00
    Adding my name to the list also. Mine was purchased directly from Microsoft. It never got hot and was mostly used with a docking station. I am very angry!!!
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167333892
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 7,858 mWh
    CYCLE COUNT 140
    *Edit - I realized that I used a credit card with extended warranty to purchase my Surface Pro 3. It looks like they'll cover it! Thanks Capital One!!
    2016-07-11T13:56:11+00:00
    I too have just encountered this problem, but i have found a solution if you can call it that.....
    make sure its plugged into a power source and go through to the following
    Control Panel > Hardware and Sound > Power Options > Edit Plan Settings
    once there click on
    Change advanced power settings
    a new window will open called Power Options, click on the check box to open the Battery options
    now click on the check box to open the Critical Battery Action options
    click on the Plugged In option, it will now be highlighted and have a drop box menu active
    click the arrow on the drop box and select Do nothing
    click the OK or Apply button and you're done.
    You now have a glorified desktop tablet PC. It will still turn itself off once you disconnect your power source, but at least it will function as normal when plugged in.
    2016-07-10T23:32:39+00:00
    Exact same problem here as well - Surface Pro 3 purchased in December, 2014. All was well until May, 2016. Between May 8 and July 6 I dropped from 42,000+ mWh capacity down to 8500 mWh, and that remaining capacity continues to plummet. I only have 245 charge cycles to date.
    I had an appointment at a Microsoft store to troubleshoot. To their credit, they spent almost an hour trying different fixes but concluded that, unfortunately, the battery was faulty and the only "fix" was to pay $450 for a refurb.
    They also suggested a factory reset, which I've now completed to no avail.
    I'm extremely disappointed, as I love the surface product, but can no longer recommend it after paying almost $1,500 for a highly portable device that has now lost all of it's portability. I'm also extremely disappointed in Microsoft support for not making any effort to make good on what their own service reps acknowledge as a manufacturer's defect. This is a premium product and I feel like I've been taken for a ride...I hope others can share their experiences for Microsoft to take notice, because as it stands I certainly will not purchase their hardware in the future.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=91f1b6b5-7a6a-4262-8807-5088cb50faf6)
    2016-07-08T17:01:09+00:00
    Oh, that's fabulous (insert ticked off face!). I go to that link and have to pay $99 to get support on my Surface. I'm certain I'd pay that $99 just for them to tell me to send it to them to purchase a $500 battery. My surface pro 3 is 18 months old! The battery should not have died this soon. This is a racket and will end up in a lawsuit, which I'm looking forward to. In the meantime, I'll never purchase another MS product until I have my battery replaced at no cost. I spent $1,400 on this product and this is unacceptable.
