2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-02T10:27:16+00:00
    I just want to add that my issue began showing up as early as February, and by late March my battery was completely dead. I purchased a replacement in device in early April. Just so we know that this isn't an entirely recent occurrence.
    2016-08-02T09:22:30+00:00
    I wanted to add my experience to the growing list of victims in this mess. I don't like going on about negative things but this has been a bad enough experience, and a common one for others too it seems, that I feel the need to be vocal about it.
    I've had my SP3 for a year and a couple of months and the battery's been on a steep decline since May. I would barely get 30-40 minutes of use out of it disconnected, but now it shuts down immediately after I unplug the power even when the charge reads 100%. Plugging it back in shows that the battery's charge is at 0%.
    I've mainly had my SP3 in a docking station since the battery degradation became too great to use without being plugged in, but even then it's prone to shutting off with the slightest bit of mildly strenuous activity. When it's really bad my SP3 shuts down without the slightest warning while doing the simplest of things such as checking for updates. These outages while it's plugged in and supposedly charging are erratic. The only certainty is that it's getting worse. A battery report shows me that the full charge capacity is down to 1,968 mWh, a small fraction of the designed capacity of 42,157 mWh. Unsurprisingly it seems to be continuing its decline. At this rate I'll have a very expensive paperweight soon.
    This fiasco has been a complete and utter disappointment. I've been trying to be patient, but the continued decline in my SP3's battery is making it extremely difficult to get any work done. Cutting my losses and jumping ship sounds a lot more appealing with every passing day I have to spend wondering if my non-portable SP3's going to shut down in the middle of something important.
    2016-08-02T09:18:10+00:00
    I found fix for this problem.
    http://forums.windowscentral.com/microsoft-surface-pro-3/433863-surface-pro-3-battery-degradation-fix.html
    """**How to FIX:**For Two weeks use your surface only on charger. If you run your surface on battery, don't drain the battery under 85-90%! After two weeks you should see increase of your battery capacity.
    That's all :-)
    I'll hope you will be lucky as me, and you get your normal battery capacity back :-)
    Good luck!!"""
    2016-08-02T08:08:28+00:00
    When I first came across this discussion a couple of weeks back, I checked my battery status, and saw the decline setting in. The battery capacity was going down day by day over a month, until it hit something around 30,000 mWh.
    However, over the past five days, weirdly enough, the battery capacity seems to be going up! It is now at 35,386 mWh. Has anyone else experienced this too with the SIMPLO battery? I have 5 days left on my warranty, and am unsure if I should go and ask for a trade-in/replacement.
    Here are the relevant parts of the batteryreports generated:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=5ff61fbd-4dd9-4a95-ab16-296f3e2ec887)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=1ed72df9-3414-4e74-a9d4-47a284e5b335)
