2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-02T07:44:36+00:00
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    We’re working through the details of how we deliver that.
    Greg,
    I'm sure you are working on this so it would be nice if you could respond here each time new Surface Pro 3 firmware is released to clarify if this is the "fix" that we're all waiting for.  I don't feel that is asking much especially as each time we have to try and discover this on our own it results in even further degradation.
    Please, Greg, do not return to the wall of silence. All we ask is to be kept up to date on progress.
    2016-08-02T05:45:21+00:00
    Greg,
    For what it's worth, I have TWO surface pro 3's, and BOTH are doing this. They are absolutely useless unless plugged in. As soon as power is disconnected, they die. Both have the SIMPLO batteries.
    I think the use of the term "limited number of customers" is a bit disingenuous. Certainly there's not an INFINITE number of customers, so by definition the number must be "limited," but this is clearly a widespread issue.
    Without reading through 40 pages of this thread, what does Microsoft want owners to do with their (basically useless) Surface Pro 3s? Should we monitor this thread, or is there a better way to keep abreast of what's happening and what remedy Microsoft will offer?
    Would you advise others to join the class action effort, in the meantime?
    Not trying to stir the pot, but with two of these devices, it's a little frustrating.
    Robert
    2016-08-02T02:47:40+00:00
    I have the same problem, When I unplug the power the computer shuts off immediately.
    It really started to go downhill after an update in May.
    2016-08-02T02:33:59+00:00
    I am having the same issues. I checked to see if I could download the update but I don't see it.
    Thank you
