Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
    2014-11-07T02:13:00+00:00
    Out of curiosity can you guys check your event log and see if you have any critical errors pertaining to a bunch of services stopping or failing to start again.  Especially the Device Setup Manager.  Let me know if you see anything there.
    2014-11-06T22:37:23+00:00
    Eric,
    I understand the frustration. The drivers/firmware/power management is way too buggy. I wish I could suggest anything other than buying an external USB wifi NIC as a solution. That's what I did so that I could use my SP3 outside my home with some amount of confidence of not being plagued with problems. I don't know if or when Microsoft will fix these problems.
    Yes, I know no one should need to buy an external adapter and that it ties up the USB port.
    Barb I really appreciate how you do your very best to help us out. It's a shame that no one from Microsoft has 2 minutes to pop in here to acknowledge us but you're vigilante and your efforts should be applauded. Thanks.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-11-06T22:21:51+00:00
    Eric,
    2014-11-06T22:16:49+00:00
    Sigh. This is so frustrating. I've had my SP3 (256GB / i7) for about two months now and none of the updates MS has pushed through have helped the wifi issue.
    People here are complaining about getting 40 - 50 MB/s throughput, yet when I transfer files to my SP3 from my desktop (on the same network, over 5 GHz wifi), I'm lucky if I see 4 - 5 MB/s transfer speeds.
    I've got a TP-LINK TL-WDR3600 Dual Band router that has separate SSIDs for 2.4 and 5 GHz. I'm using only the 5 GHz band for the SP3, and the router is set to N-only for the 5 GHz.
    My SP3 consistently:
    • Won't reconnect to wifi after being asleep (wifi shows up as "Limited" with no internet connection). I have to either disconnect from the wifi network and reconnect, or since that doesn't always work either (!!), restart the machine.
    • Transfer & throughput speeds are terrible.
    • AND wifi drops! Will be fine for X amount of time, while in use, and then randomly drop to Limited / no internet connection. Not anything related to coming out of sleep, during actual use. Will have to restart or disconnect from wifi then reconnect.
    All of this while: fully up to date on all updates and drivers and connected to a 5 GHz N-only dual band router (that is not sharing an SSID with 2.4 GHz).
    What prompted me to post here today was that last night my SP3 completely stopped connecting to ANY 5 GHz signal. I restarted. I toggled the wifi. As many out there have suggested: I enabled Hyper-V, restarted, adjusted the wireless adapter power settings, disabled Hyper-V, restarted... and it still wouldn't connect to the 5 GHz wifi. It would only connect to the 2.4 GHz SSID. And the speeds were obviously atrocious compared to even the not great 5 GHz speed. Out of desperation I started playing with the router settings and changed the 5 GHz band from "11an mixed" to "11n only" and finally that allowed me to reconnect to the 5 GHz band with the SP3. Ugh!
    Incredible that this hasn't been fixed since the release of the SP3. My wife's Macbook Air that is a year and a half old has zero issues on our 5 GHz wifi. My WP (a Lumia 920, two years old, which I love) has zero issues on our 5 GHz wifi.... yet a brand new SP3, which wasn't cheap, is terrible on wifi!
    What is causing this? The Marvell adapter drivers? Why hasn't this been fixed!
    I posted a couple of times that my solution until Microsoft figures this out, is to get a nano USB WiFi adapter.  I bought one after I had the WiFi issues and never looked back.
    For a while before the 10/28 update I was able to use the SP3's internal adapter but MS messed it up again on 10/28 so I gave up and went back to my trusted $9 nano adapter and it is rock solid.  Makes me wonder how come a small company can get something correct and a large corporation can't get this right after so many months now.
    I love the SP3 so I hope MS solves the WiFi and heat issues, but until then using a WiFi adapter will allow you to use the device and enjoy it. Just make sure to disable the internal WiFi after you are done installing the drivers of the new one.
    It's sad that the only way to get reliable wifi on a Surface Pro 3 is by using an external wireless adapter and lets not forget that the SP3 only has one USB port so it's a lose lose situation.
    2014-11-06T22:09:54+00:00
    Yeah, I'm seriously considering it. Just seems ridiculous that it even has to be considered.
