Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
    2016-09-24T16:24:07+00:00
    Zach,
    We have a surface pro 4 , seems to have the same issue. Can you direct me to a link or instructions to increase dual band speed?
    Paul
  2. Deleted
    2016-03-09T15:42:02+00:00
    For me the issue was the routers used channel!
    I had the exact same 144mbit/sec issue, fixed at that rate, or some 130.
    Now I checked my router and saw that on my used channel 6, much other WiFi routers were working. then i switched to channel 4, instant got 500mbit/sec on battery usage. So I did a sleep state, woke up the surface, still full 500+ mbit/sec
    So if anyone is still running into this issue, first update to latest drivers, then change your WiFi channel in the router.
    2015-12-09T20:56:59+00:00
    That fixed the problem, thank you! I downloaded the drivers from the link, installed, rebooted, and my speedtest jumped to 120mpbs. I incorrectly assumed that doing a Windows Update was giving me all the latest drivers.
