Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
    2014-06-21T22:11:14+00:00
    Same problem here. Keeps disconnecting and I'm sitting in front of the router. My Samsung TV is 60 feet away and my laptop is on the other side of a brick wall and they don't have any connectivity issues. A tablet without the internet is worthless!
    2014-06-21T22:06:52+00:00
    Thank you! That was an immediate improvement. I'll test and report back some results when I get home, but I'm out running around sitting in a coffee shop at the moment. I previously wasn't able to connect to the Wi-Fi here so I tethered to my phone's 2.4GHz Mobile Hotspot. After rolling back the driver, my SP3 immediately connected to the Wi-Fi here and it appears to be stable.
    2014-06-21T21:58:44+00:00
    I've been speaking with a number of other friends/family/colleagues that also picked up Surface P3s on Day 1 and they seem to be having the same issues. 802.11ac compatibility seems to be the worst, but even 802.11n speeds seem to be worse than other stable devices.
    Try downgrading the driver.
    of course, this is just a workaround.
    2014-06-21T21:54:28+00:00
    So I got my sp3 yesterday and it was blazing fast on wifi. I did all the new updates and after doing so every web page was loading slow or timing out.
    I did some searching and there a bunch of people with the exact same problem "Other forum"
    I cant use my 5ghz network which is my wireless ac. I have a netgear nighthawk and the only way i can use this sp3 is by using the 2.6ghz now.
    Please fix this. I'm shaking my head that first update screwed something up.... i already went through nightmares with my sp2 so this isnt a good start :(
    One more idea. If it was working before the update you may still have the drivers old version in your SP3 so it may possible to downgrade it. just an idea.
    Exactly, your can go back to this one an see if that helps.
    2014-06-21T21:52:20+00:00
    Yea, this is getting to look like a rerun.
    The news got out earlier today and the i3 and i7 models will be available on 1 August.  The i3 model was the one I was wanting - I don't need super fast or a lot of storage to use one for testing purposes and do some minor document work.
    Oh yes, Microsoft invented a pair of pants that recharges mobile devices in a pocket (cellular phones).  I can't wait to see somebody wearing those in a rain storm!
