So I got my sp3 yesterday and it was blazing fast on wifi. I did all the new updates and after doing so every web page was loading slow or timing out.
I did some searching and there a bunch of people with the exact same problem "Other forum"
I cant use my 5ghz network which is my wireless ac. I have a netgear nighthawk and the only way i can use this sp3 is by using the 2.6ghz now.
Please fix this. I'm shaking my head that first update screwed something up.... i already went through nightmares with my sp2 so this isnt a good start :(
One more idea. If it was working before the update you may still have the drivers old version in your SP3 so it may possible to downgrade it. just an idea.
