Been fighting my SP3 I5 since I got it Sunday as well. Overall it's a nice little setup. The 802.11ac works but dog slow... almost better if I stay with N instead of ac. Pen connects about 1/2 the time. Getting tired of it. Should have waited for the I7
version I preordered. Maybe they'd have had more time and hopefully gotten this straightened out. Thought that by SP3 they would have it down pat....
Will try deleting the driver to see how that goes. If not it's rebuild and back to Bestbuy.
You want the driver dated 4/24 an with .67 on the end.
I finally got the work around mentioned in this, and other threads, working. Here are the steps I took:
1 - Disable auto updates
2 - uninstall battery driver
3 - uninstall ac adapter driver
4 - uninstall wireless driver - The difference I did this time was to uninstall the software associated with it. You'll get a dialog box with a checkbox.
5 - reboot. Give the device a moment to reinstall the drivers and then reconnect to the network.
Go into your updates and you'll see the 6/19 update that you DON'T want to install.
WiFi is faster than before, but I'm still only around 54-72mb.
