Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
I just re-installed the update using the 1607 ISO keeping my apps and files. Now its working fine.
Additionally, before reinstalling, "powercfg /energy" wouldn't generate a report. Now it does. Seems something was screwed up in the power settings.
Hi, all
I have solved the issue by recover my SP4 using official recovery USB media, listed here: https://www.microsoft.com/surface/en-ca/support/storage-files-and-folders/create-a-recovery-drive?os=windows-10&=undefined.
Then I updated to the anniversary update of Windows 10. Then the CPU works fine now.
The method is mentioned in the link: https://www.reddit.com/r/Surface/comments/4w0bke/cpuclockspeed\_doesnt\_change\_anniversary\_update/
Same issue with my surface pro 4, hope it get fixed soon :/
No wipe needed, I kept everything and re-installed the updated on top of the existing system.
