Surface pro 4 - clock speed of CPU keeps the same
2016-08-03T03:19:10+00:00
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
2016-08-31T01:11:30+00:00
Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
92 additional answers
    2016-08-05T16:03:21+00:00
    I updated to 1607 and reset my SP4. Then I use the Media Creation Tool to re-install the update. Luckily, the clock speed of CPU steps down.
    I just don't understand why Microsoft distributed such a "special" windows update to their Surface product.
    After using SP4 for a while, the CPU stays at 2.90GHz always. Nothing helps to solve this problem. :(
    2016-08-05T15:32:43+00:00
    I have the same issue in my surface book, I just update to 14393 via media creation tool
    2016-08-05T15:26:42+00:00
    I had the same problem and it was solved by re-installing the update via the Media Creation Tool:
    https://www.microsoft.com/en-us/software-download/windows10
    You do not have to create a USB stick, only execute the tool to update your device.
    Did you wipe everything and reinstalled windows from scratch? Or did you keep your existing installation and only re-applied the update on top of it?
    2016-08-05T14:53:33+00:00
    Fixed it for me as well.
    Thanks !
