Surface pro 4 - clock speed of CPU keeps the same
2016-08-03T03:19:10+00:00
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
2016-08-31T01:11:30+00:00
Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
92 additional answers
    2016-08-05T12:45:22+00:00
    I had the same problem and it was solved by re-installing the update via the Media Creation Tool:
    https://www.microsoft.com/en-us/software-download/windows10
    You do not have to create a USB stick, only execute the tool to update your device.
    2016-08-04T18:09:56+00:00
    I tried to reset my computer. But nothing changes, the CPU is still high.
    2016-08-04T13:21:52+00:00
    I completely agree... But I am leaving in 3 days for a month, and I won't have the resources with me that I have now to fix any issues just in case it gets really bad (like having my server send down all my files). So, I decided to just do it now. It worked.
    2016-08-04T13:15:27+00:00
    Rebuilding my whole pc is NOT an acceptable solution.
