Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
Well, I was able to fix this by ... REFORMATING my device and doing a clean install. Now my device slows down and speeds up when necessary (thank God).
I normally wouldn't format it so willy nilly, but since I had just formatted it 2 days prior, then it wasn't that big of a deal. Luckily all my content gets synced down from the server (documents, pictures, videos, installers, etc) - otherwise this would have been a complete nightmare.
Same problem here. Core m3 stays at 1.5Ghz. Not clocking up or down.
Great Anniversary Update!
Great, I upvoted yours as well. But search feedback because there are numerous other ones that had already been sent to MS. Upvote them all.
