2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-17T03:50:12+00:00
    Since we are going to continue to disagree, I'll just end it here. No disrespect, just leaving the conversation. Good luck.
    2016-03-17T02:54:04+00:00
    You are so wrong! Whether it should or should not be the case is irrelevant.  The fact is that you were lucky that the MacBook pro never came out of sleep while in the sleeve.  If it had it would have been toast, literally.  I have given good prudent advice, if you choose to ignore it that's your privilege and your disaster waiting to happen.  I have seen many laptops ruined in this manner during my long career in IT.  I hope others will see the logic in my advice and the risks in your reply.
    2016-03-17T02:30:01+00:00
    Sorry, but that's shouldn't be the case. I put a sleeping MacBook Pro in a sleeve for YEARS and never had it come out hot or lose ANY battery life. (If this were the case, you'd see warning labels everywhere!) Microsoft has some work to do with Intel on Power Mgmt.
    Also, I own both a dGPU SB and fanless core M SP4 and neither do the hot bag thing when sleeping or hibernating. (The SB used to, but no more. I've tried both since the last update, but I did turn off Fast Startup on SB to see if it helps battery drain and Windows Hello issue, now resolved with latest update.) My issue is battery drain on the SB. The fanless SP4 has been amazing!
    2016-03-17T00:10:10+00:00
    My SP 4 i5/256 8 is going hot while is asleep even with the latest updates (16.03.2016)!
    Kumulatives Update für Windows 10 Version 1511 für x64-basierte Systeme (KB3140743)
    Just a word of caution!  Anyone putting a sleeping sp4 in a sleeve where all ventilation is cut off is asking for overheating damage.  Never, never put your sp4 in a sleeve unless you have used Shut Down or Hibernate.  Even if Microsoft eventually solves the sleep power issue you should never put any sleeping laptop in an UN-ventilated sleeve or case. Hopefully you have not been doing this.
