2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-18T20:59:17+00:00
    At least for me, the Intel Beta Graphics driver 15.40.20.4404 has solved the heating issue while SP4 i5/256/8 is in sleep mode and the black screen after sleep issue completely.
  2. Deleted
  3. Deleted
  4. Deleted
