2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-16T21:31:17+00:00
    My SP 4 i5/256 8 is going hot while is asleep even with the latest updates (16.03.2016)!
    Kumulatives Update für Windows 10 Version 1511 für x64-basierte Systeme (KB3140743)
    2016-03-15T13:39:39+00:00
    The post in reddit seems to be related to Surface Book. Is it applicable for Surface Pro 4 as well?
    2016-03-15T12:33:09+00:00
    For those who are experiencing battery drain or other issues after the latest firmware update, take a look at the following post and follow the instructions.
    https://www.reddit.com/r/Surface/comments/49g46p/i_am_going_to_make_one_post_to_convey_a_fix_for/
    It seems that Surfacebooks shipped with a corrupted system file and this is causing issues.
    Using the above instructions I have fixed a corrupt system file on my machine, and it is behaving much more normally now (1-2% drain in sleep - most of the time).
    2016-03-10T22:22:17+00:00
    On my third unit (not including a surface book that I returned for an SP4), all of which have have same issues with fan constantly running, burning through ridiculous amounts of battery while supposedly sleeping, and failing to resurrect itself from a sleep.   All updates have been installed and nothing seems to work.  This is without a doubt the single most frustrating electronics experience I have ever had.
