2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-10T01:25:03+00:00
    Just purchased a base model fan-less SP4 after having months of intermittent issues with my SB (which seem to be somewhat resolved now.) This SP4 has been *flawless* right out of the box. I use both machines daily. But I think these newer models are a little more reliable. I would suggest anyone having severe issues to restore whole laptop, if that doesn't work, return it for a new one.
    2016-03-10T01:02:32+00:00
    I have the same problem described in this thread.  I just bought the i5/256 Surface Pro 4 a few weeks ago, and installed all updates on 2/22/2016.  Today is the first time that I had it asleep in it's sleeve and just realized it was overheating with the battery drain issue.  I just tried disabling the Fast Startup power option; so, I will wait and see if that truly helps.
    I too love this machine!  It's been awesome otherwise!  Any help would be much appreciated.
    2016-03-07T15:54:30+00:00
    Hi All,
    Josh
    Josh - I have the update installed.  However, this has not changed the frequency with which the fan is running - in fact, it runs while the computer is booting and nearly constantly thereafter, even when the computer is not warm. It is loud and annoying in the extreme. I have tried turning on the passive cooling option rather than active, and reducing the maximum processor state to 50% (35% while plugged in) and the minimum to 5% for both battery and plugged in, and turning off the Windows Hello feature in Windows 10, all to no avail.  I am on the verge of returning this thing - if it is even possible at this point. It did not exhibit this behavior when I first purchased the machine, the loud and constant fan began more than a month later.
    For reference, I have an SP4, i5/8MB/512GB machine.
    2016-03-06T08:24:09+00:00
    Same issue exists for my brand new surface pro 4 and finally after failing all the attempts , took my surface to service centre . They said the the issue is not with the surface but with the intel processor and soon they will provide an update for the issue.And also suggested me , not to put my surface into sleep mode. So we have to wait for the update. I am currently update for what they are provided to the customer. Its a know issue .
