2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-05T19:24:56+00:00
    Have you switched off Fast Startup in Power Options to see if it helps? It has resolved many issues for me including Windows Hello intermittently working and there is NO startup lag once you disable it, otherwise I wouldn't have switched it off. Try it and see what happens.
    2016-03-05T19:15:32+00:00
    I've had 3 hot-bag incidents since installing this update where, while in sleep mode, the surface 4 was overheating and draining the battery.
    I've used the sleep study utility and this is an example of what it reports:
    CPU C0 Time Processor 91% 0:48:08
    CPU C0 Time.Non-attributed Time Processor 73% 0:38:43
    My Srum data shows this:
    \Device\HarddiskVolume3\Windows\System32\LockAppHost.exe [AndrewsPro4] 27188391 19243743 0 0 0 0 0 7944648
    I've confirmed the update has been installed.
    Any suggestions?
    2016-03-05T13:34:36+00:00
    My SP4 has been fine inexplicably since the day before the last update.  Since I used hibernate after 2 hours, I never again experienced wake issues, but when it did go to Sleep, it would get very warm.  So I have a new observation about that issue.
    If I set it to Sleep for all settings, never hibernate (plugged and docked), and push the power button, it goes to Sleep without heat. But if I leave the SP4, after 15 minutes, the screen is set to go off, and it Sleeps in 20 minutes.  Going to sleep that way, it still gets warm.
    SO, my conclusion is that MSFT may not have entirely fixed this, as it is not sleeping on its own, it requires the act of telling it to sleep (power button).
    Anyone else notice this?
    2016-03-05T10:07:22+00:00
    After complete reset and reinstallation of the updates, all is OK. No battery drain anymore.
