2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-01T15:11:07+00:00
    I had something similar happen this past Sunday (yes, after the February updates), though the screen came back on in my case. Put it to sleep (or so I thought) and a few hours later it was very warm to the touch and battery had drained about 60% over 2.5 hours. Only had Chrome and Outlook 2016 open. I saw a number of ACPI embedded controller events in the system log. I have the i7/256/8 config. Clearly hibernate is still the way to go.
    Edit:  meant to add, after the 2/17 updates I did a complete wipe/install using the latest drive image from MS and reinstalled everything. Had hoped that would be beneficial.
    2016-03-01T14:57:23+00:00
    ALso display wont come up after. Need to keep hold the power button to turn it off completely.  Now thinking of selling the surface pro 4.  My 2000 bucks is gone. So disappointed after buying this laptop
    2016-02-29T09:55:42+00:00
    I am considering this. I only bought it on Saturday, so not much to lose. Hope it will not be in vain.
    2016-02-29T09:39:52+00:00
    Have you considered reformatting your Surface to start anew and see if that fixes the issue?
