2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-29T09:25:19+00:00
    Still have the battery drain while asleep issue on my PRO 4 m3 after the latest February update.
  2. Deleted
    2016-02-28T06:07:56+00:00
    Bought my surface pro 2 weeks back and having the same problem .. Charge lasts for only 3.5 to 4 hrs of normal usage like browsing .. Also it overheats a lot
    2016-02-27T18:31:23+00:00
    I ran a sleepstudy.  I am not sure I know how to read it.  But it appears during the past few hours when it was in sleep, and the SP4 was rather warm, this was running 70% of the time:
    USB xHCI Compliant Host Controller (\_SB.PCI0.XHC)
    Does anyone know what that means?  I assume this USB thing (the computer is docked) is what is causing the heat, and it should be in sleep?  If so, why doesn't MSFT see this?
