2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-27T12:35:48+00:00
    After the 2/2016 update to fix sleep, I think things are worse. A test where I didn't use the SP4 for 24 hours after putting it to sleep yielded Zero battery power. At 100% I put it to sleep and then into my laptop bag. The next morning I push the button and I got the power icon button on the screen but then immediately it shut down. Do you think a restore after the firmware is required?
    2016-02-27T11:42:31+00:00
    What should I do if I have all 3 exclamation marks on the items that you have posted as well as an exclamation mark on the "Surface Embedded Controller Firmware". Each exclamation mark's device status is:  "This device cannot work properly until you restart your computer. (Code 14)"
    I tried following the procedure with no results. The systems in the restart procedure, after shutdown the device will power on normally, display the surface logo, than the screen will go black for around 10-15 seconds, during this time the type cover back-light will still turn on if touched, after this the device will power off. From here I will have to manually power on the device with the power button, which usually results in a normal start up sequence with no updates applied, this can be confirmed via re-checking the device manager and all 4 items still have exclamation marks attached.
    Please help
    2016-02-27T07:55:33+00:00
    I'm having the same problem with the new update installed.
    2016-02-27T03:38:31+00:00
    Just noticed this - although no exclamation in my SP4, I did check the driver date on all those three items and here is what I found...strangely I don't see any drive points to 2/17 update.
    • Surface Management Engine - 1/27/2016
    • Surface System Aggregator Firmware - 1/27/2016
    • Surface UEFI - 1/29/2016
    Should I install the update manually? Thanks for clarifying!
    I also have no drivers from 2/17.  Perhaps this is the root of the problem with the new fix?  JOSH?????
    Cool your jets.  Those are the correct dates for the latest firmware upgrades from SurfacePro4_Win10_160401.  Nothing strange about them at all.  If you were to exam the zip file SurfacePro4_Win10_160401_0.zip you would find these dates in the inf files for each firmware update.
