2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-27T03:15:40+00:00
    Just noticed this - although no exclamation in my SP4, I did check the driver date on all those three items and here is what I found...strangely I don't see any drive points to 2/17 update.
    • Surface Management Engine - 1/27/2016
    • Surface System Aggregator Firmware - 1/27/2016
    • Surface UEFI - 1/29/2016
    Should I install the update manually? Thanks for clarifying!
    I also have no drivers from 2/17.  Perhaps this is the root of the problem with the new fix?  JOSH?????
    2016-02-27T00:27:08+00:00
    Only one more that I can think of.. Do you have the system connected to WIFI while its in sleep or hibernation? This is called connected standby and is the reason my system overheats or drains excessive battery. Make sure that is unchecked in system power and report back after a day or two.
    2016-02-27T00:05:47+00:00
    2016-02-26T23:55:21+00:00
    Thanks for the note...my firmware section has no warnings and they all look normal icons. This is after applying 2/17 update, but I still have battery drain and overheating issues in sleep mode. Any other tips?
