2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-03-03T13:39:36+00:00
    I have this problem since last time when I updated my windows. I updated my win about two weeks ago. Idk what to do because not just the battery drains also I have to restart my computer everytime that I want to use.
    2016-03-03T03:09:44+00:00
    I have given up on sleep mode.  When it comes back, external HDMI is dead and battery is also drained. Need to restart anyway.  Best to just shutdown.  Thankfully shutting down and restarting is very quick.
    2016-03-03T01:31:53+00:00
    I'm still having this issue too even after the Feb firmware updates. My Surface was in sleep during my commute to the office this morning and when I took it out of my bag it was very warm and had drained 11% in 40 minutes.
    I ran "powercfg /sleepstudy" and this particular Connected Standby session shows 0% of the time spent in DRIPS mode. Unfortunately when digging into the details of this session, there's nothing concrete to explain why the CPU was active the entire time. Does anyone know how to interpret this, or where else I could look to better understand what was keeping the CPU active?
    Data:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8de68532-8970-4384-96e3-8b32b9113641)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3ee8fe07-def2-4104-b72d-b09c99683b56)
    2016-03-02T11:48:05+00:00
    Hello!
    May I ask what troubleshooting steps you have tried?
    Kind regards
