2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-01T19:42:55+00:00
    Can you provide instructions on how to disable Hello? i dont have it turned on, but dont know how to "disable" it to fix the battery drain problem.
    2015-11-01T19:39:02+00:00
    Can you please elaborate on how to disable it? i don't have it turned on, but is there somewhere i can go to further "disable" it?
    2015-11-01T13:35:24+00:00
    It's been found that windows hello is the cause.  Try disabling it and restart.  That should solve your sleep issues, while killing an awesome feature until it gets fixed.
    2015-11-01T02:00:33+00:00
    Seems to be an issue with all i5/8GB/256GB models.....I've had two and both have the same problem with the battery draining while asleep.
