2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-02T12:45:48+00:00
    Yes - I woke up this morning to find that my SP4 i5/8/256 was HOT to the touch.  It was plugged in and supposed to be in sleep mode.  It's much warmer than when I am actively using the SP4 (like right now).  It seems like it's been doing this the last couple of days.  Windows hello is active.
    Microsoft, help!
    2015-11-02T04:06:05+00:00
    What a shame! I was hoping it would be a nice feature to make security hassle-free ...
    2015-11-02T02:48:56+00:00
    It's not abnormal for them to drain fast in the first few days due to indexing and a variety of other initial maintenance tasks. But Windows Hello creates is very own problem, and that one will not go away. Not until Microsoft fixes it.
    2015-11-02T01:12:24+00:00
    This worked for me. Someone else mentioned something about indexing...I had to reset my index once because Windows was constantly indexing and that seemed to fix that problem.
