2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2017-02-09T21:47:31+00:00
    I can not thank you enough. Was on the verge of returning my Surface Pro 4 which I only purchased a month ago because of the battery life(could never get it more than 3.5 hours for full charge) and running hot issue. Thought I'd turn to the internet and stumbled over your solution. Now it is showing over 9 hours on full charge and even after a lot of use it doesn't even get warm. Why on earth are Microsoft still selling these with such a fundamental flaw when the solution is here? Do the care so very little for their customers? Thank you once again, I'm now not regretting paying such a premium price for what was nothing more than a hand warmer.
    2015-11-01T01:55:24+00:00
    Also bought a i5/256 GB Surface Pro 4 and experiencing the same issue. Will someone from Microsoft please comment on how the devices were sold as having a sleep mode which does not work? It uses just as much battery while "sleeping" as it does during use. Mine drains at over 10% per hour while asleep.
    2015-10-31T12:52:45+00:00
    Having the same issue, has Microsoft commented on this as it is a widespread one?
    2015-10-30T13:02:59+00:00
    To put it simply, sleep doesn't work yet (yes, I have all updates manually installed).  You can see what your surface was doing during sleep by running "powercfg /sleepstudy" from the command line with admin privileges.  The report will tell you that your cpu is running full blast while sleeping.
    Go into your power settings and change the behaviors for lid close, power button click, etc... to hibernate.  IME, hibernate vs sleep on the surface is about 3 second difference in start up time.  You'll have little to no battery drain after that.
