2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-06-24T09:23:06+00:00
    I am having trouble with my SP4 as well which was purchased in January this year. I called MS support and they uninstalled the battery drivers but I don't have much hope in that.
    On a fresh Windows installation, I put it in sleep with 65% battery in the evening and in the morning it is totally dead. Running powercfg /sleepstudy /duration 1 I can see that it just carried on draining the battery when in connected standby. What causes this?![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=6c4b08e2-f654-4a05-ab34-95677f8f8f31)
    2016-06-14T17:26:19+00:00
    I got my replacement as well (4th one), this one seems to functioning better. I think the issue is faulty h/w with my previous machines since applying the patches (successful install) didn't fix the battery drain and heating issue.
    2016-06-14T08:05:02+00:00
    I just got a replacement for my October 2015 Surface. They confirmed that the power issue is most likely related to some faulty hardware/battery, let's see if I can finally enjoy the full Surface experience and reliability.....
    2016-06-12T17:45:37+00:00
    I just puted my Surface Pro 4 i7 256 on my side, only closing the keyboard to sleep mode, without hibernating or exiting. It had lots of ventilation around, it was not on direct sunlight or either executing any task, but it had a Word page open and 5 internet pages open. When I pulled it up to work again, it was so hot that it almost burn and the computer cooling fan started working to cool the equipment. I don't think this should happen!
