2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-06-12T01:36:30+00:00
    Absolutely correct. The reason MS doesn't address this properly is that unmaking garbage is hard to do. I have a 256gb i5 SP4 and a Samsung Tab Pro S running Win 10 and the Tab Pro S runs Windows better than this SP4. Microsoft has proven again hardware is not there specialty. When the SP5 comes out I won't make the mistake of buying it even if the reviews lie through the roof. I find the SP4 annoying and MS can't fix it regardless of how many remote desktop troubleshooting sessions they try.
    2016-06-10T17:25:00+00:00
    Interesting, my SP4 is just over one month old and I'm having the same overheating while in sleep issues, and when I check the update log I find "failed to install" for both of those updates mentioned above. I have an m3 processor.
    2016-06-10T04:55:08+00:00
    Me, too, Carlos. I'm using Core M SP4, not any major issues with it until latest update. Battery drains quickly and they have succeeded in making my SP4 heat up my bag just like my old SB was before I sold it. Please please please fix this and stop fiddling with it.
    2016-06-10T03:24:48+00:00
    Fabio..
    I'm not showing the 5/24 updates, either. My SP4 started overheating in my bag today at work. I took it out and it nearly SCALDED my hands! Well over the safe range of it being hot! (When I put it in my backpack earlier, it was at 100%, when I took it out at work and it was scalding hot, it was at 4%) ;/ Seriously???!! I think I will contact Microsoft for a replacement. I'm using the core m low end SP4, never had an overheat issue on this until now (whereas on my SB, before I sold it on eBay, had that issue all the time and I couldn't handle it.) So, what do we do now??
    This has always been, and continues to be, severely UNACCEPTABLE. Especially when my Surface Pro 4 nearly burns the skin off my hands (yes, that's how how it was.)
