2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-06-06T11:35:31+00:00
    I have those drivers installed. And since i rolled back to the 14295 build, my sp4 has been quite stable.
    The hello-camera still seems to have som driver issues though, it doesnät initialize every time I try to use it to log on to windows, but it works most of the time.
    It seems that the lates build on the slow ring doesn't work to well with the surface hardware.
    Let's hope the next build is better.  Maybe I should stop the insider builds until the final release this summer.
    Thanks!
    2016-06-04T22:55:23+00:00
    I read somewhere that having airplane mode on causes drain. Has anyone heard or tried this?
    2016-06-04T22:30:23+00:00
    My surface pro says I am up to date but this issue still persists. No what do you suggest?
    2016-06-02T19:28:47+00:00
    I have a Surface Pro 4 i5 128gb and for the last few months it has been overheating really fast when it has been in use for more than an hour, and even faster if the charger is plugged in. This makes the fan go really loud and the computer run very slow.  I wonder if there is a fix for this, because the heat makes it uncomfortable to use, and the poor performance it gives in this state its annoying, since this is a high end computer.
    I have the Surface with the latest updates.
    I hope this has a software fix, because the closest Microsoft Store is really far from my home.
    Thanks!
