Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-10-08T04:46:28+00:00
    hi.
    basicallyh, how do all of you use the sp4.
    1. direct charging it even though it is already 100%, continue to direct charge unless if you want to use it portably.
    2. direct charging it even though it is already 100%  unplug power supply and use the battery until 0% then recharge again?
    1. direct charging right until 100% unplug then use battery power only until 0%?
    2. any other ways?
    2018-10-07T02:14:19+00:00
    why not just use Alt+F4 and select "Shutdown" from the pop up menu?
    I just tested killing explorer.exe (to simulate having a problem with it) and Alt-F4 did not cause a Shut down menu.  However, pressing Ctrl-Alt-Delete made me wonder why not use that dialog's Power button for its Shut down (or Shift-Restart for its Shut down option).
    2018-10-06T13:11:13+00:00
    Question, why not just use Alt+F4 and select "Shutdown" from the pop up menu?
    Rgds WP
