Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2017-11-28T14:15:09+00:00
    I'm saying that I don't think they want to actually shut the machine down dead cold, or give an option to do so.  If they did, there's no reason it would take five generations of machines to implement it.  So they would rather try to "minimize" battery drain and keep the features they want implemented.  And we see how well that is working.
    2017-11-28T14:10:37+00:00
    So are you saying that this behavior of draining battery while device is "shut down" is actually an implementation by Microsoft on its devices? Because when I contacted their support, they said this should not happen
    2017-11-28T14:07:08+00:00
    IMHO..  The future m$ sees is one of 'always on', a smartphone-ish direction type of interactivity.  So allowing, or setting a precedent, of "shutting down" isn't really what they want to do.  So they would rather beat their heads against the wall trying to balance battery drain issues with upper management product direction.  If they really wanted to preserve battery life in the "off time", they would physically shut the machine down cold.  "OFF" is something I'm sure their engineers could do if they really wanted to.  I just don't think they have any intention of implementing it.
