Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2017-11-28T13:51:33+00:00
    I've had my SB4 for 2 years come January 2018.  Obviously MS has no interest if fixing this issue.  I've seen no attempt other than replacing with another SB4 with the same issues.   I will be replacing my SB4 the first of the year and it will NOT be a MS machine.
    2017-11-28T13:23:09+00:00
    I have sent it back a second time and demanded a new one.
    Out of curiosity, how can you tell if the new one is refurbished?
    2017-11-27T02:04:55+00:00
    I am curious if this battery drain while device is shut down only occurs in the sp4 or are all surface pro products affected by this.
    And I also want to know if it is the common business practice for warranties to replace a defective device with a "mint" device and not with a brand new one? Like for apple, if your macbook is defective, do they replace you with a brand new device?
