Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2017-11-30T22:33:39+00:00
    It also happens when my SP4 came from MS .. refreshed ..
    Difficult to say if it come from an HW, A FW or an OS problem.
    MS does not talk to much about i ans seems to be without solution about it ..
    This problems is here for more than one year now  !
    2017-11-30T22:26:37+00:00
    I have this problem and my surface is full shutdown when battery is 20 %
    I  think this problem is often after a firm ware update
    2017-11-29T23:22:12+00:00
    That's right it should not happens ...
    The computer behaviour is quite weird and sometime when you choose hibernate rather than stop battery does not drain when off.
    A fresh setup does not solve the problem, whatever the reason is, it is an MS issue as they mastered hardware and software.
    This is not serious for a professional device from a professional maker.
    After the windows 10 mobile disaster (I got 2 of these) this is hard to support.
    And when you contact MS, always the same process:
    • try to reinstall
    • send it back
    The best you can have is to get a new device with the same problem or .. another one :(
