Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
    2013-02-11T23:15:39+00:00
    Wacom got back to me:
    "You would have to contact Microsoft for support as this is their product."
    2013-02-11T22:11:30+00:00
    I'm beginning to see the phrase StylusGate in my crystal ball.
    2013-02-11T22:09:11+00:00
    You're thinking of the HP TX2, which was N-Trig, the TM2 came next and reverted to a Wacom digitizer.  I've got both of them.
    Also, Intuos pens have never worked with Penabled devices.  You have to buy specific ones to work with Tablet PCs.
    2013-02-11T21:52:58+00:00
    Yeah, well they lied to you on the phone: it is a Wacom, I've tested it with my other Wacom penabled pens and they were recognized (pen from a Modbook and HP TM2).
    The HP TM2 is an NTrig not Wacom device.   I just tried a Wacom Intuos 2 pen and it was not detected by the Surface Pro.
