Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
    2013-02-12T02:10:31+00:00
    Thanks for the update.  Can you give us an idea on time frame?  Are we talking days, weeks, longer?  I actually purchased my pro specifically to sketch in PS, and my keeping it is dependent on those features.
    Thanks in advance,
    Ryan
    2013-02-12T02:09:16+00:00
    Just to clarify: does that mean that you'll be adding WinTab support (so that I can use my non-Photoshop programs like GIMP) or that Adobe will be adding Ink API support?
    Please be the first :(
    2013-02-12T01:50:24+00:00
    Thank you for the update!
    2013-02-12T00:48:45+00:00
    Good news!  Mary Jo Foley was able to get an answer from Microsoft.  https://twitter.com/maryjofoley/status/301021316641878018
    http://www.zdnet.com/microsofts-surface-wifi-updates-pen-improvements-more-cover-colors-in-pipeline-7000011130/
    "Surface Pro uses Windows Inbox Drivers and APIs (application programming interfaces) for the Surface pen, which support advanced features such as pressure sensitivity and eraser functionality. There are a number of apps in the Store that leverage these new Windows APIs and can take advantage of all that the Surface pen has to offer. The Surface pen does work with Photoshop, which runs on Surface Pro, though advanced features such as pressure sensitivity and eraser functionality may not be available at this time. Microsoft is working with the necessary partners to make advanced features of the Surface pen available across a number of applications in the near future."
    Yes, that's marketing/PR speak, but hopefully it means that they have contacted Wacom and are looking into adding Wintab API support to the digitizer drivers so that everything will work in Photoshop, Illustrator, Camera RAW, Corel Painter, Lightwave 3D, etc.  Meanwhile, yes the pressure sensitivity works great in that "Fresh Paint" app you can download.
    Hello Everyone,
    As Adam Z Lein mentioned we are working with the necessary partners to make the pen Advanced features available.
    Thanks again for the feedback.
