Surface Pro 6 gets stuck at 0.40GHz (While charging) (SOLVED)
2019-06-23T19:00:04+00:00
I'm posting to report a bug that seems to occur on rare occasions. Every once in a while my Surface Pro 6 gets stuck at 0.40GHz while it's plugged to the adapter but works fine on battery. I've had this issue occur about 4-5 times throughout the 6 months I've owned it. The only fix for this issue is re-installing the Surface Pro 6 firmware. I think it's more firmware related than hardware, or maybe the chip that holds the firmware is defective? Anyways, I thought I'd report this issue because it still needs fixing.
SOLVED - This was fixed with the latest (Nov) firmware update.
2019-10-25T03:04:31+00:00
Thank you for reporting the issue.
A fix for this issue is currently available through our Release Preview ring in the Windows Insider Program.  When joining the Windows Insider program you will stay on a retail build of Windows, but get a sneak peek at on-going development of apps, drivers, and other quality updates.  As of the date of this post, Release Preview installs Windows 10 version 1909.  In addition, you will also receive prerelease updates for Surface before they are more broadly available.  The Windows Insiders program is designed exclusively for people who want to be involved in the process of trying out new updates before the final release to everyone.
To join the Windows Insider Program go to Settings> Update & Security > Windows Insider Program and click Get Started.  You will need to provide a Microsoft Account and when prompted choose Release Preview. You can always go to Settings> Update & Security > Windows Insider Program to opt out of receiving preview updates.
This fix will be generally available through Windows Update as soon as it completes our quality testing.
51 additional answers
    2019-09-09T16:38:55+00:00
    Mine is well under the warranty, so I am just going to have it replaced.  I have already logged the issue with their support desk and took videos on my phone of the behavior.  It has been less frequent lately, but still happens at inopportune times.  Sometimes, unplugging it, waiting a few minutes on battery and then plugging it back in resolves the issue.  Other times, that trick does not work.
    I have found the state that is turning on "Prochot", but can't seem to find a way to disable that control.  It might be a faulty sensor on/near the CPU that is stating that the temp is too hot, even when it clearly isn't hot at all.  They might find a software fix, but since the unit has been out for almost a year, I'm guessing that they will lose focus on trying to resolve it.
  2. Deleted
  3. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2019-07-22T13:42:57+00:00
    You can't actually reinstall FIRMWARE - or downgrade it. Try the consumer
    version of the Surface Diagnostic Toolkit
    https://support.microsoft.com/en-us/help/4037239/surface-fix-common-surface-problems-using-surface-diagnostic-toolkit
    which can often fix most software and driver issues. It will pull down any
    updates your are missing.
    2019-07-22T13:31:42+00:00
    I have this problem too.
    How do I reinstall the firmware?
