Surface Pro 6 gets stuck at 0.40GHz (While charging) (SOLVED)
2019-06-23T19:00:04+00:00
I'm posting to report a bug that seems to occur on rare occasions. Every once in a while my Surface Pro 6 gets stuck at 0.40GHz while it's plugged to the adapter but works fine on battery. I've had this issue occur about 4-5 times throughout the 6 months I've owned it. The only fix for this issue is re-installing the Surface Pro 6 firmware. I think it's more firmware related than hardware, or maybe the chip that holds the firmware is defective? Anyways, I thought I'd report this issue because it still needs fixing.
SOLVED - This was fixed with the latest (Nov) firmware update.
2019-10-25T03:04:31+00:00
Thank you for reporting the issue.
A fix for this issue is currently available through our Release Preview ring in the Windows Insider Program.  When joining the Windows Insider program you will stay on a retail build of Windows, but get a sneak peek at on-going development of apps, drivers, and other quality updates.  As of the date of this post, Release Preview installs Windows 10 version 1909.  In addition, you will also receive prerelease updates for Surface before they are more broadly available.  The Windows Insiders program is designed exclusively for people who want to be involved in the process of trying out new updates before the final release to everyone.
To join the Windows Insider Program go to Settings> Update & Security > Windows Insider Program and click Get Started.  You will need to provide a Microsoft Account and when prompted choose Release Preview. You can always go to Settings> Update & Security > Windows Insider Program to opt out of receiving preview updates.
This fix will be generally available through Windows Update as soon as it completes our quality testing.
51 additional answers
    2019-09-07T04:34:30+00:00
    I was talking to MS staff via online chat for getting some support and got the usual response: developers are aware of the problem and there will be another patch for fixing this issue. That doesn't say much, for sure. But it's a start and made me keep the device for now ... unplugging it from time to time is a feasible and bearable workaround for me.
    2019-09-06T12:30:54+00:00
    **Update:**There is no fix for the problem. Re-installing firmware didn't fix the problem, and the issue keeps returning. I've made a video on YouTube, and based on Reddit and forum threads, the problem seems to widespread on many Surface Pro 6 and Surface Book 2 devices. Here's a video of the problem: https://www.youtube.com/watch?v=jcAtuUjthcI
    The issue continues to return no matter what, but it doesn't happen as often these days. My solution is to unplug the Surface Pro 6 from the wall, and that will temporarilyresolve the problem. We need a real solution from Microsoft because this isn't acceptable for such an expensive, or frankly any laptop or tablet. It's difficult to pinpoint the exact problem because it happens intermittently and not all the time, but it's a major issue because the bug inevitably returns.
  3. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2019-06-24T17:13:43+00:00
    🕱   Warning from a Moderator:
    You may have received an email/reply to your question with a single toll-free number suggesting that you call Microsoft.<br><br><br>Do NOT call; this was a bogus message posted by a scammer.<br><br><br> <br><br><br>The phone number does not belong to Microsoft and the post has been removed.<br><br><br>Official support phone numbers for all supported countries can be found athttps://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.<br><br><br> <br><br><br><br>
  4. Deleted
