Teams for Android does not work with Bluetooth.
2022-12-06T00:51:43+00:00
Teams will not recognise Bluetooth headphones when joining calls.
I have tried restarting, clearing cache, clearing storage and reinstalling. I have tried multiple different models of headphones from completely different manufacturers. I have tried different phones.
This is not a user issue. This is an issue with the application. Several posts have been made.
Please fix it.
EDIT: the 'Nearby Devices' permission will fix this issue in most cases. For me, it worked temporarily (for one call) and then reverted to the same issue. However, the issue does now seem to be fixed - I have had consistent success for about 2 months now. I am assuming that a recent update to the app has fixed an issue that was causing this.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
2023-06-14T03:03:30+00:00
Hi Chris,
I had the same problem, and I noticed it was because of the permission setting of TEAMS.
I reinstalled Teams and accepted the "Nearby devices." access and it works now.
Sabrina
90 additional answers
    2022-12-06T01:32:53+00:00
    Hi Chris,
    Sorry to hear you're experiencing this issue!
    I suggest deleting paired Bluetooth connection on your device.
    From a Home screen, do one of the following to ensure Bluetooth is turned on from your Android device:
    1. Settings Connected devices Connection preferences Bluetooth.
    2. Settings Connected devices.
    3. If necessary, tap Bluetooth.
    4. Settings Bluetooth.
    5. Tap the appropriate device name or the Settings icon Gear (right).
    6. Tap 'Forget' or 'Unpair'.
    Once done, attend a call or meeting and choose Bluetooth > Select "connect" in the Bluetooth settings dialog.
    Select "Bluetooth".
    Let me know if I can help you further!
    Best,
    Jayzar
    2023-01-11T06:56:56+00:00
    I enabled all the permissions that were disabled, just to try.
    But I just checked: enabling "nearby devices" permission back is enough to fix the problem. Location permission is not mandatory.
    2023-01-04T10:42:38+00:00
    Same issue here on Samsung Galaxy S20.
    Teams was working with Bluetooth. I updated Teams on 13 December 2022.
    Tried everything!
    2022-12-28T13:27:01+00:00
    I had MS Team working with both my bluetooth earbuds till two months back on my Samsung A55 , but they stopped working all of a sudden.
    Now I just cannot use any bud with MS Teams. All other apps work well.
    Now I dont know if its MS Teams problem or a Samsung problem. Note Samsung is desperate to promote Bixby its Assistant against Google Assistant. Although disabled, Bixby tends to insert itself into the mix, every time you try to bypass it.
    MS Teams and buds work perfectly with my Android (non Samsung) Pad, I would suspect Samsung is upto something here.
