You are looking for SensorService and start it automatically
Power & battery settings in Windows 11 won't open
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
2024-02-19T02:04:18+00:00 -
2024-01-08T17:28:07+00:00 Thanks for finding the fix to this issue!!!
2023-12-23T00:24:07+00:00 I have the same problem. Once I click on the "Power and Battery" tab ......Setting closes down.
Also update to 23H2 fails after installing 75%
2023-12-09T15:08:04+00:00 sometimes it opens but takes too long
sometimes it just wont
i tried safemode unfortunately it crashes the settings app when i open power&battery
its really annoying -
2023-10-03T00:56:27+00:00 Thanks. I'll cross my fingers!
