Power & battery settings in Windows 11 won't open
Reported
2023-10-02T14:41:09+00:00
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
    2024-09-25T05:56:12+00:00
    thank you
    2024-06-14T00:55:23+00:00
    tried to reset sleep time.computer wil not accept , and retains factory settings
    2024-05-23T18:39:04+00:00
    Worked for me. Thanks AdMaverick!
    2024-05-20T11:02:47+00:00
    STILL NOT CHARGONG
    2024-03-04T00:48:37+00:00
    Thank you all! Problem solved.
