battery is not charging it shows 0 charging
Power & battery settings in Windows 11 won't open
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
2025-02-08T18:47:51+00:00 -
2025-01-01T21:12:25+00:00 I have question about battery, It is always on low while is on charging on laptop when is in use. Why is it slowly on charge?
2024-12-21T09:47:09+00:00 The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
feedback-hub:?contextid=215&feedbackid=05cc22dc-73b8-4fb7-be46-3b6952a78ab1&form=1&src=1
Deleted
2024-11-19T14:31:47+00:00 The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
POWER&BATTERY WON'T OPEN
battry full
