Thanks! Regards, Dale Henderson
Power & battery settings in Windows 11 won't open
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
2024-03-03T21:53:38+00:00 -
2024-03-03T20:52:09+00:00 I don't get updates in the same way that a computer operating system like Windows does. Instead
give me a time im ready
thank you
2024-03-03T20:41:49+00:00 Vedant: how did you update your system? Please advise. Thanks!
2024-03-03T20:39:43+00:00 How did you update your system? Some sort of Windows Update ? or did you re-install Windows 11?
2024-03-03T20:37:15+00:00 This didn't work for me!
